I installed my unit a week ago and week ago, then yesterday I got a message on all cameras that device is offline and check for power and enternet connecion.
check unit I could not get it to power up again.. what's wrong.../
What are the LEDs on the base showing?
no lights come on....when i ret to repower the base
At minimum, the POWER led should be Green ( left most led )
If powered on via the ac adapter and you get nothing,...it's the base or the power supply.
Contact Netgear.
