Arlo wireless mounted outside
After hanging my cameras outside from under the roof, with the outdoor adjustable bracket, the picture shows upside down. Is there a way to flip the picture instead of having to drill holes on the stucco wall?
Yes.
Go to settings - video settings and select invert image.
I used the magnetic "table mount" under my soffit so the cameras could be mounted the correct way up so the PIR motion sensor was closer to the ground. They're sufficiently high that they're difficult to steal even though they're only holding on to the mounts by magnets. This might be something to consider if your soffits are high and your camera motion detection needs improving
