Arlo wireless mode accessible even when camera turned off
According to the software, once the camera is turned to off, the mode should not be accessible. But I can easily access the mode even with the camera turned to off. This concerns me because now I wonder how secure the camera is to outside influence.
Anyone else run into this issue? Will there be a software update soon? For the record, I did not used to be able to access the mode; this glitch just showed up out of nowhere.
JRoberts76,
The mode can still be edited/changed, the camera will just no longer respond to the set mode after it has been switched off.
For example if you have 2 cameras and camera 1 is switched off, you can still set your system to Armed allowing camera 2 to detect/record motion.
