Arlo wire free cameras compatibility with arlo wired cameras
Hi,
I currently have 2 arlo wire free cameras and a controller. I would like to purchase arlo wired cameras as long as I can use the same controller for all arlo cameras. Is this possible? If so, which wired model should I look for?
Many thanks
Richard
Are you referring to the Q cameras? If so, they don't use a base - they're self-contained and use your home WiFi.
If I use the Q arlo cameras with built in wifi, which software do you use to view the cameras?
I use kguard with other wifi cameras, could that same software be used with the Q arlo cameras?
No. Only the Arlo software works with the Arlo cameras. And any Arlo camera will work on the Arlo app or web site.
OK. The arlo software that I currently use will work with Q arlo cameras!
Thank you.
