Re: Arlo wire free cameras compatibility with arlo wired cameras
  • 4 Replies
  • 197 Views
Highlighted
Hi,
I currently have 2 arlo wire free cameras and a controller.  I would like to purchase arlo wired cameras as long as I can use the same controller for all arlo cameras.  Is this possible? If so, which wired model should I look for?
Many thanks
Richard
Model: VMC3030 | Arlo Wire-Free Camera
Highlighted
Are you referring to the Q cameras? If so, they don't use a base - they're self-contained and use your home WiFi.
If I use the Q arlo cameras with built in wifi, which software do you use to view the cameras?
I use kguard with other wifi cameras, could that same software be used with the Q arlo cameras?
Highlighted
No. Only the Arlo software works with the Arlo cameras. And any Arlo camera will work on the Arlo app or web site.
Highlighted
OK. The arlo software that I currently use will work with Q arlo cameras!
Thank you.
