  • 5 Replies
  • 4121 Views
MurrayK
As title says, will pick up motion but will not save the recording. However, it will save the recording when i go into live mode and manually record.
Model is VMS3430
MurrayK
It is somehow working this morning, it must have updated itself last night
5 REPLIES 5
steve_t
Master Master
Firstly, what firmware versions are your base station and cameras on?
Secondly, are you using ARMED mode or a custom made mode and are the rules in that mode to record on motion detection?
MurrayK
Camera :
HW VersionVMC3030
Serial Number48B45B7A37BDB
Firmware1.2.2688
Base:
HW VersionVMB3010r2
Serial Number48D3627DA03BF
Firmware1.4.2695
Mode is set to All Motion On
Try resetting ( power button ) your base first...the SW versions you have are older version and  prob causing the issue
Check under SETTING > DEVICE re update sw
should be
cam = 1.2.10342
base= 1.8.8.0.11528
MurrayK
steve_t
Master Master
You might notice the "All Motion On" mode is now "Armed" with the newest updates
