Arlo wifi 4 cámaras y base station con conexión free
  • 2 Replies
  • 2589 Views
Warlor
es posible conectar la base station con routers en serie o red para ampliar la señal wifi a las cámaras.??
En casas grandes construidas con ladrillo y cemento la señal wifi entre base station y cámaras es muy baja o pobre.
que puedo hacer ??
tengo entrada ADSL  conectada a 2 routers en red o serie que me dan buena señal wifi en toda la casa y terreno para móviles IPads Notebook etc.
mi idea es conectarla a este circuito para mejorar la señal wifi entre cámaras y base station.
es posible esto??
gracias
Google translation:
you can connect the base station with serial or network routers to extend wireless signal to the cameras. ??
In large houses built with brick and cement the wireless signal between base station and cameras is very low or poor.
What I can do ??
I have ADSL input connected to two routers on a network or series that give me good wifi signal throughout the house and land mobile iPads Notebook etc.
my idea is to connect this circuit to improve the wireless signal between cameras and base station.
is this possible ??
You can use a long Ethernet cable or a WiFi extender to help position the base in a more favorable position for all cameras.  The WiFi between the base and the cameras can't be extended using a WiFi extender so the position is important.  In certain situations, you may need more than one base to be able to cover the whole area so all cameras have a good connection.
Google translation:
What I can do ??
is this possible ??
Warlor
I followed the suggestion a with a good succes in base Station and cameras.
For that I bought one mire set of cameras and bese.
Thank you very much.
