Arlo unable to add device
What lights are on on the base station? When you say reset, do you mean a power cycle or a full factory reset?
I believe the button you were talking about is the power button. To do a factory reset, you have to use a paper clip to access the the reset button on the back of the base. You press and hold this button for ten seconds. This will reset everything to the way it left the factory After that you will have to add all your devices back starting with the base.
Your problem may have been router related, possibly a firmware update.
Brian
Are you able to add the base station? The base station must be added first before you try to add the cameras.
Brian
You add the base station just like you would the cameras in the device section. But since you are essentially doing a new installation here are the instructions for that:
For the original Arlo Wire Free HD system the link is:
https://www.arlo.com/en-us/images/Documents/Arlo_Wirefree/arlo_wirefree_um.pdf
For the Pro models the link is:
https://www.arlo.com/en-us/images/Documents/ArloPro/arlo_pro_um.pdf
Brian
Drop back and punt.
Remove all devices in Settings, My Devices. Press the reset button on the base until the LEDs flash amber. Let the base reboot until the power and Internet LEDs are solid green (if they're not solid green, nothing is going to work). Use the Add Device button on the Devices tab to claim the base. Sync the cameras.
Preeth,
Are you still having trouble after following jguerdat's instructions above? Please let us know.
