Arlo takes so long to load. Why?
Does it differ when using WiFi vs. cell service? WHat phone/OS? Older/slower phones take longer - my Nexus 6 is very definitely slower than my Pixel 3 XL, by leaps and bounds.
I believe this issue belongs to the file server of Arlo storage.
After June 5, 2019, everyone got 640x352 resolution with 24 frames per second. (Still nowhere near HD).
But now, this fix increases the data transfer rate between all customers and Arlo cloud storage, causing all delay loading.
This entire failure belongs to Arlo because their storage data transfer rate is not fast enough to meet the needs of all customers.
The delay on a computer browser is very much less so I don't believe it's a backend issue.
jrutherford, when did you having this probelm?
I happended to me too, when that happen, what I did was close the brower with Arlo program,
then open the brower again, start up the Arlo program, go to library, everything return back to normal.
Hi Jrutherford
I totally agree. I have a galaxy S5 and it takes forever. I did try a newer flagship model and it was much faster but certainly not spectacular.
Try using Puffin browser for Andriod (from Google Play Store). I has flashplayer built in and loads the Arlo web interface in a flash!
Regards
Bagabond
