I currently have a home system with three cameras and have the application on my iPad I have a second home that I want to install a new system at Will the second system be a separate application the iPad ? I assume I will set up the base station there as I did at my home Thank you Jim
Same app or browser access but two possibilities.
1) If all cameras are 5 or less, use the free plan. Bases are free, cameras are limited. Upgrade your plan if desired.
2) Install the second system using a differnt email address. On one system, share access using Settings, Grant Access to the other account's email address. Make sure you select cameras to share. When completed you can view all cameras using that one login.
