Arlo stopped working after 3 weeks of use
Try using the Armed mode and see if that works. If not, the fastest method would likely be to remove all devices in Settings, factory reset by using the reset button, and add the devices back in. Make notes of any setting/modes/rules first to help the rebuilding process. If all this pain doesn't help, a trouble ticket would be in order.
when i switched to armed mode it worked but when i switch back to the previous mode stops working normal
Then your mode is the problem. Is it an old mode from last year? Those have proven problematic and generally should be replaced with a new mode with exactly the same settings. We don't know why the old modes have issues, just that they do. In any event, try a newly created mode.
Georgeperea83,
Did creating a new mode solve the issue? Please let us know if you are still having trouble.
