Arlo standard camera battery life
  • 1 Reply
  • 657 Views
suprgnat
I have one camera with good wifi signal and not too many recordings that chews through batteries in a week, or two max.  The other cameras are fine.  What gives?
I've removed batteries, I've re-synced.
Hardware H11
Firmware 1.2.118180
On another note, the post requires "Labels" but doesn't explain what it wants and logging in to Chat, which timed out anyway, required a phone number with no guidelines as to what format it required, just a criptic message explaining that how I wrote it doesn't work.  Obviously I figured both out, but how about a USEFUL error message like "phone number requires numbers only with no dashes?  Who writes this stuff and who do they imagine their audience is?
Take one of your "good" cameras and swap location with the troubled one... see if the issue is location or the problem follows the camera.
If the issue follows the camera , contact Netgear Support
( if the new one does the same, pick a better location )
