Arlo schedule
  • 1 Reply
  • 2292 Views
Dallas1957
Schedule is for all cameras together what I can see??
I would like to schedule each camera so you can turn off some
off them where people often walks when you are at home.
For example your front door and you will be able to still
get alerts from backside of the house.
Is this possible to fix?
Dallas 1957, Sweden
You can do that now...what you have to do is split up your cameras into groups ( or singles ) that make sense to your uses... like inside/outside or front/back.
Create new MODES by using ADD A MODE and customize them to your needs adding the cameras you need ( cause right now you have ARMED ( all on ) and DISARMED ( all off )
see;https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-modes-and-rules-and-how-does-Arlo-use-...
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-new-mode-for-my-Arlo-Wire-Fre...
