I have a standard Arlo with 4 cameras that I recently added 3 more cameras to.
I purchased the elite plan.
However I can only see 4 rules under a mode even though I have created 6 rules.
The new cameras I can see and look at but none of the motion detection and email seems to be working and I can't see the rules to edit them.
1. Can I have more than 4 cameras under a mode.
2. Can I have motion detection and recording for more than 4 cameras.
3. If yes to above how can I view the new rules and get them to activate under the active mode.
Thanks!
1) yes... I have 8 under the same mode
2) yes, I can armed all the cameras usng the default ARMED mode
3) something sounds like it got glitched when setting the extra cameras.
So... easy to hard , stop when it works ...
I would do a power button reset of the base
Remove the 3 cameras and bring them back again ( settings>for camera>remove device )
Do a full reset of the base to restore all defaults and reset them ( hold in reset till the front leds flash anber, give it a couple mins to reboot, if cameras aren't there you will have to resync them all as if new
