Arlo - periodically one of my three Arlo's disconnect from the base station. Not the batteries.
I have 3 Arlo's. Periodically one of the three goes off-line and I get a message that its disconnected from the base. I remove the affected device and move the batteries around in the Arlo. The Arlo than reconnects with the base station and resumes working. I check the batteries each time this occurs and they have nearly a full charge. What gives. This issue, which occurs with each Arlo on a repetative basis negates the Arlo's reliability. When this problem occurs all I do is open the camera back and move the batteries around, wait for the blue light to flash and the unit reconnects. Is this a common problem and if so is there a fix? If not then I need to remove the Arlo's and install a more reliable security system. Until this issue is resolved I will not recommend Arlo's to anyone.
Hi @Hg1997
