  • 3992 Views
Gazzza47
My arlo is only showing black and white in a room that is not poorly lit.  Is there a way to adjust the Black and White threshold?
Maybe the site burped and switched posts made at the same time?  If a post has ben edited, there's a notification of that in the header of that post.
Can't answer the actual question since I never had VueZone.  However, it wouldn't be "color sensitivity" but the threshold for light level that triggers the switch from color to B&W and the hysteresis to switch back.  I can certainly see a different system having a different threshold as well as specific cameras doing the same due to differences in sensors and/or electronics.
No. The choice is to increase light level. Move the camera to a different room or outdoors to see if color shows up. If not, open a case with support.
BTW, you did remove the plastic over the camera front, right?
Gazzza47
This was not the wording of my original question.  Why was the question I submitted edited? I asked if the Arlo had different color sensitivity to my old VueZone cameras, which worked fine and in color in the same locations.
