Arlo notification
Are you using phone app or computer? Will then go to the other?
Have you verified under the mode that you're using that notifications is checked for the cam(s) you're using?
If above done, delete the app and reinstall too.
I'm so sorry but this hasn't work.
Still don't get the push notifications
I use phone, verified that all cameras are set to push notifications
I did do the other suggestion of uninstalling amd re installing,
Still no push notifications
amdevons,
What model phone are you using and what OS version?
Samsung galaxy 5
Sorry not sure where to find OS.
Andriod 6.0.1 is what is on my phone
amdevons,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
