Ok, I have read loads about this motion detection not working and gone through every little details of setup. everything is spot on. the running man symbol lights up when motion is detected.Both cameras work for manually, and push notification is working but it never starts recording a clip. nothing.
I have tried creating my own modes. i have tried turning off on one camera and all shows it should be working. the running man greys out on the camera i disable motion on, then comes back highlighted when i re enable. everything should be fine, but it never records.
Any idea's?
Mine is now working perfectly
All i did was to run the motion test on all cameras.Light coming on on camera, saved settings, then just left them. sometime later all recordings now appearing in the library. may have been a server issue and just coincidence or maybe needed that motion best before it would start recording.
