My wife and I are going on vacation tomorrow for a week and wouldn't you know it that NONE of our cameras are recording. They show the picture "live" and when you walk in front of them, they even show you walking by. HOWEVER, none of them will record and nothing shows in my library. We have unplugged the unit and reset all of our cameras but it continues to not record. Any help soon would DEEPLY be appreciated. Thanks!!
It will not record if you are viewing LIVE. Try it when not viewing LIVE.
Motion/recording should be indicated by the running man turning amber - is that just a typo?
If power cycling the base and opening and closing battery doors doesn't work, try removing the cameras from Settings, My Devices and resyncing them. If still no good, I'd suggest a reset by removing ALL devices as above. Add the base using the Add Device button on the Devices tab and sync the cameras. Make sure to note your settings and modes/rules/schedule before resetting to help rebuild what you already have changed.
Thank you for the advice, I will follow your steps and hope for the best. Either way, I'll follow up and post my results. Just as side note, something that is happening that I find interesting/strange is that now (this is prior to following your steps as listed above), not only is the running man turning amber (or green for those like me) but on my app the number of "recordings" from my arlos is still be displayed in the upper right corner. However, when I click on the number to watch the "recordings," nothing is there to watch. For instance, this evening I had been away from home for about 4-5 hours and was receiving notifications of motion and by the time I got home, I had received 11 notifications and on my app it indicated that I had 11 new recordings, when I clicked the "11" to watch them, there are no new recordings to watch and the last one that was recorded was on Jan 26th.
Anyways, thanks again for the advice and I'll keep everyone posted.
I am having the same issue -live recording works but no motion and I did resync the camera. The other three work fine. It was like this from the begining when I bought them last month but I thought I just had settings wrong settings and it would resolve but it did not.
By any chance does the camera have a rule in your modes? If you removed the camera during troubleshooting, you may need to add a rule for it again.
This worked for me so it may be worth giving it a shot if you currently use a custom mode. Quick and easy fix to what had been a frustrating issue to say the least.
If you need any help feel free to ask and I'll do what I can to help get your issue resolved also.
Best of luck
Good catch. That's one reason I suggest that you don't change the Armed mode (at least very much) so you have a fall-back mode to test with. Create custom modes instead since they can easily be created/removed/changed as appropriate for your specific needs.
AL310,
It sounds like your system may not be on the latest firmware if you do not see an "Armed" option within modes.
Check your firmware by navigating to Settings > My Devices > select base station/camera > Device Info > Firmware
