Hello. I’ve noticed an influx of other posts about phones getting stuck on the Arlo logo screen when the app is opened.
Has Arlo discovered a solution or do I need to switch systems?
The error occurs on WiFi and off.
iOS 15.2.1
Arlo version 3.5.12
Works on my wife’s phone
See photo.
iOS 15.2.1
Arlo version 3.5.12
See photo.
7 REPLIES 7
Haven't seen any post on this issue in a while and was short lived, I don't have the problem. Since your wife's phone works try reinstalling the app or rebooting your phone.
Without scrolling much, I saw there were two last month.
I’ve done the whole turn off turn on.
Uninstalled and reinstalled.
Cleared iCloud data.
Reset network settings.
Everything that was suggested in previous threads, I’ve tried to no avail.
Does the app do anything if you tap or swipe the white bar at the screen bottom?
It’ll close out/minimize with the white bar, like normal.
Which model iPhone are you using?
iPhone 11 Pro.
MWAR2LL/A
MWAR2LL/A
Can you test again on iOS 15.3
