Arlo how to improve a 1 bar camera signal
Hi - have an issue where one of my cameras is right on the edge of the signal - has one red bar. I can't move it closer. Is there anything I can do, like attach a booster, which would improve the signal?
You have a few options...
1) move the base closer using ethernet cable to centralize the base for all cams
2) use an wifi extender (with ethernet port ) to move base closer
3) run a second base ( no limits to number of bases on any level ( nor location ))
