Arlo has been off since the 8th.
Mine has been off since the 8th. This happened before when they did a update. Doesn't matter what I do can't get it to connect. It took hours before on the phone to get it right. I am growing very tired of this system.
Barttg13,
What error message is indicating the camera is "off"? You might consider opening and closing the battery compartment door to reboot the camera. Pay close attention to the LED indicator on the camera: What do the different LED behaviors on my Arlo Wire-Free camera mean?
It's possible that the batteries are depleted and need to be replaced.
An amber Internet LED is a problem. If you're absolutely sure the router and cable to the base are good, the base is having an issue connecting. That could be a bad port on either the router or base, the base is somehow faulty or the router configuration is blocking the connection. I'd start with a factory reset on the base, holding the reset button until the LEDs flash amber. Does that get you a green Internet LED?
