Around two days ago I've stopped receiving email alerts. I receive non-email alerts on my Arlo iOS app and I can see the video clip in the library but no more email alerts. I've rebooted/power cycle the base station, router and modem, but no luck. I haven't done anything to the system (base station or cameras) at all and everything has been running fine up until a couple days ago. Are the Netgear Arlo servers down? Also, just to mention, I'm not receiving email from my second camera as well.
meyekle,
Check your spam folder to make sure the alerts are not being filter. It's also possible your email provider is blocking Arlo email alerts and you may need to contact them to prevent blocking them in the future.
meyekle,
Yep, that's the solution but I don't understand why after 3 years of use that all of sudden arlo alerts are being tagged as Junk. Anyway, thanks for your help nonetheless.
meyekle wrote:Yep, that's the solution but I don't understand why after 3 years of use that all of sudden arlo alerts are being tagged as Junk. Anyway, thanks for your help nonetheless.
I see this too with other non-Arlo e-mails. They are usually false positives. Just whitelist them and check your spam folders often. 😞
I just posted a simlar question. Sorry, hadn't seen this one before.
Same issue. Email suddenly stopped. They are not in my spam folder, I use Gmail. This appears to have started after I turned on Push notifications as well as email.
What's the deal?
