Arlo detects motion, says clip in library, but no clip is there
i get notification that my camera detected motion and links to the library for the video. Aflo app shows there is a message. There is a "1" on the library icon indicating a video is available. When I go into the library, there is no video. Camera is set to record 30 seconds of video. 3 bars on wifi. What is going on?
Check that the filter is clear and not set for other cameras ( looks like a funnel in the upper corner in library )
Or just click on the number of videos in circle to go directly
Thanks. Previously had done both suggestions before the post.
Sinisbob,
Are you able to produce a manual recording via live stream? Does it arrive in the library? I have not been able to replicate any issues with recordings arriving in the library via motion detection or manual record. Are you still seeing this behavior?
I returned the product to where I purchased it. Not happy with it at all.
