Arlo cams are slow connecting.
My internet is getting high speeds. What can I do to make my camera's connect faster?
Is the slow speed of connection related to opening a mobile app, web portal or slow to start live streaming in mobile app or web portal?
Mobile le
@Truth2121 wrote:
Mobile le
Not sure what you mean by "le"
Can you clarify more precisely what is slow?
The cameras are slow connecting when I am using the app.
I have a base station.
Three Arlo Pro 3 Floodlights
Arlo Video Doorbell
Two Arlo Essential Spotlight Cams
Two Arlo Essential Cams
What are your Internet speeds,both up and down, as well as the latency? Use speedtest.net to check.
Might also be worth rebooting the phone as well as the web client to test - https://my.arlo.com
Internet Speed - from my computer which is an ethernet cord
Download - 923.60
Up - 932.23
Idle Latency - 4
Download Latency - 6
Upload Latency - 10
It sometimes can take a few seconds between the time you open the app to when all the current status is displayed on the the screen. Is that what you mean?
Or are you talking about the time it takes to livestream the camera from when you request the livestream?
Or something else?
I am referring to the time it takes to live stream the camera from when you request the livestream.
How long Is this delay? there will be a normal delay with internet based cameras.
They have gotten better. I turned off the base station and turn it back on as someone suggested.
