Arlo cameras on chromebook
I cannot play video from my Arlo cameras on my Toshiba Chromebook 2. Can anyone help
9 REPLIES 9
If Chrome won't play the video directly, you may need to install a different viewer such as VLC to use after you've downloaded the videos manually. Does the rest of the Arlo interface work properly, including live view? What error or symptom are you getting?
Arlo will not play live view on my chromebook it just sits there until it times out with no error message. The rest of the interface works OK. I have no problem on my ipad,iphone or samsung S6 or my desktop running windows 10.
It's an issue between the computer and flash... Live view requires flash to run
And I don't think the Chrome OS browser supports Flash, just as the Android versions don't.
I am using flash version 25.0.0.127
I don't have a Chromebook so I have to ask all the questions. What browser are you using Flash with? Perhaps that's the issue.
I am using google chrome.
AFAIK, Chrome doesn't support external Flash. The desktop version has it built-in and the mobile version is a nonstarter for Flash. Educate me - does a Chromebook allow this?
Did somebrowsing and discovered that the Chromebooks do support Flash. Check this thread out to see if it helps.
https://community.spotify.com/t5/Desktop-Linux-Windows-Web-Player/Web-App-not-working-on-Chromebook-...
