Arlo camera won't sync
Camera won't sync, can someone tell me which lights should be on on the NETGEAR modem. I only have two coming on. Thank you.
Power and Internet LEDs should be green. If not, nothing is going to work. What do you see?
Thank you - both those lights are on - but none of the others.
Pam
You didn't asy if they are green - amber is an issue.
Assuming the left two LEDs, power and Internet, are green, the next step is to briefly press the base sync button - don't hold it. When the base LED is flashing, press the sync button on the camera. That should start the camera LED to slowly blink blue until it syncs, shown by rapid blue flashes, or it doesn't sync, shown by amber flashes. What happens when you try?
Thank you, the two left buttons are green, pressing the sync button on the base makes the third light flash but no response on the camera when sync button pressed. Sorry for delay in reply, base station is in an outhouse which is sometimes not accessible because of work going on in our drive.
Sounds like the batteries are dead. It would be useful to check them with a voltmeter - dead is ~2.75-2.8 volts. If they read higher than that, perhaps they're not making contact with the battery door properly. Simply place the batteries in their slots - don't push them down. Let the battery door do the work. When the door is closed, you should see the LED flash blue as it wakes up and connects to the base. Is that what you see? Does it connect to the base or at least allow you to sync?
I am having the same problem. It shows 3 cameras offline. I removed one and tried to add it back it just keeps blinking amber
What are the base LEDs showing? Did you happen to hold the base sysnc button when trying to sync? If so, don't. Just briefly press the button and then press the camera button.
New firmware introduced the blinking Internet LED to alert to network traffic.
I've never had to sync a camera after changing batteries. When the battery door was closed, the camera would blink blue rapidly as it reconnected to the base. If needed, remove the camera from Settings, My Devices and resync. Be sure to only briefly press the base sync button - don't hold it. A power cycle of the base may help, too.
