B0bby_k wrote:
When I go to "how long do you want to record?" On only 1 of my 4 cameras the slider bar is grayed out and won't let me adjust it. It's stuck at 15 seconds recording, but shows 10 seconds. I've tried to re-synch the camera, reset batteries, disable/enable options, etc. everything I've tried hasn't work and any assistance would be great. Thanks!
Go to settings, pick camera
Use REMOVE DEVICE for that camera
Open and close battery door to reset camera
Reboot the base with the power button , allow about 1-2 mins for it to come back online
Resync the camera as if new make sure its a QUICK push on the base sync button then the camera a sec or two later.
Camera should now have all default settings and you should ba able to adjust the record time. ( btw, save is on the prev page bottom )
