My Arlo camera with firmware 1.3.317, hardware H7 seems to do less registrations of movements. At the same time the picture is slightly red all time. The battery is 70% and the Wifi works well.
What is the problem? Anyone😉
Wht is the sensitivity set in your modes and rules? You may need to increase it. If the IR filter is stuck you can get a red/pink image during the day but fine at night. Open and close the battery door to see if that helps. If not, open a case with support:
Your WiFi has nothing to do with Arlo which uses its own WiFi connection.
Thanks for quickly response. I can not find any menu to adjust sensibility on the camera, only sharpness that has been set to 100%.
Read the FAQ here on changing sensitivity. ALso consider creating custom modes for full control. There are a lot of useful FAQs that can help you solve many issues.
Quickly, use the Mode tab, click on your base and edit your modes. Each camera that has a rule has a sensitivity setting. Be sure to save.
