Arlo camera keeps disarming itself. Will arm when it is on schedule but disarms randomly.
  • 2 Replies
  • 4327 Views
Jcreech
My Arlo camera keeps disarming it’s self. It will at first arm it self when I put it in  schedule or arm it then out of the blue it’s  disarmed for no reason I am very frustrated I would never buy there camera again or  recommend  Them to anyone. Please help thank you
JessicaP
Hi Jcreech,
When you have the camera on default "Armed" mode, does the camera disarm on its own? If it's only happening when you're on schedule mode, try to remove your schedule and re-set it up to see if that helps.
JessicaP
Hi Jcreech,
Jcreech
Thank you that  seems to worked.
