Hello,
I just got an Arlo wireless system with 2 cameras. The 1st camera is working well since 2h. The other one keeps disconnected every 10-15mn. I changed the batteries with no success. Each time I need to do the sync to bringit back and after 10mn it disappears. Even the sync process is not working as well as for camera one (have to remove batteries once or twice to get it synced).
I would suspect a faulty camera. What do you think?
Thanks for your help
Bonjour @Philippe67
Félicitations pour votre premier message sur forum Arlo.
Vous avez écrit votre message sur le forum francophone. Pour que tous les utilisateurs puissent le comprendre veuillez reformuler votre demande en français s’il vous plaît. Si vous préférez d’écrire en anglais je peux déplacer votre message vers le forum anglophone.
Bonne journée à vous
Justyna
Equipe Arlo
Bonjour,
Oui vous pouvez le déplacer vers le forum anglophone.
Merci
Philippe
Wow! My high school French from 50 years ago actually let me figure out what was said, at least at a basic level. I'm stopping now - my head hurts.
Hi jguerdat
Please focus only on the 1st message at the top. It is in English. The others in French are just about movig the post on the right place.
Philippe67,
This sounds like it could be an interference or range issue. One way to further isolate the issue would be to swap the affected cameras location with the camera that is behaving normally. If the issue follows the camera this could indicate a problem with the camera itself.
In fact I exchanged the whole package, not only one camera. Sorry for the confusion.
