Arlo camera battery on a disabled camera?
If a camera is disabled does it use battery? I seem to go through batteries rather quickly. 😞
arlo wire-free camera
If a camera is OFFLINE, yes...it uses more battery then if online .
So make sure you leave your base on or resync cameras asap if they go offline.
If in DISARMED mode, the cameras use little or almost no power ( same as if you turn them off in settings )
