  • 6 Replies
  • 3574 Views
Gokart9
Looking to find out if anyone has bought and is happy with any brand / model of rechargable CR123.  I see some on amazon have 650mAh rating and some up to 2000maH.  Guessing different battery types NiMH and others have different ratings and maybe the higher number is not always the best chioce?  I think the camera come with non-rechargable 650mAh.
6 REPLIES 6
steve_t
Master Master
Arlo recommend and have tested Tenergy. In fact, you can buy them through the website
https://www.arlo.com/en-us/products/arlo/tenergy_rechargeable_battery_charger.aspx
steve_t
Master Master
Anything that says 2000mAH is likely to be fake
manfredz
Hero
Hero
Also keep in mind only the Tenergy 3.7v rechargeables are certifird by Netgear.  If you use others and they trash your camera, you may have warranty issues.  Unfortunately the Tenergys are hard to get in many countries other than Canada or USA.
GGood clues of types to avoid are, as mentioned above. any batteries offering more than 700Mah.  Also any advertised for $2 or$3 each
steve_t
Master Master
I can't get Tenergy so I got some Ultrafire 880mAH batteries and they're brilliant
manfredz
Hero
Hero
I also got a set of Nitecore's.  Getting as good performance as the Tenergys.
The Tenergy's are certified for use but as long as you get batteries that have built-in over- and under-voltage protection you should be good.  Don't use batteries without this protection, especially the 2000+mAH-rated ones, since fires and meltdowns have occured and your warranty would be voided.
