Arlo blinks blue then rapid amber then rapid blue; won't sync
  • 1 Reply
  • 2613 Views
petra802
I have sync'd two of the three included cameras and they appear to be functioning fine for now.  The third camera is acting squirrely.  I put the base station in sync mode; then press the SYNC button on the camera and it flashed slowly blue for about 10 seconds then it rapidly flashes amber for about 5 seconds THEN, it flashed rapidly blue.  This sequence of colors does not show up in any of the troubleshooting documentation.  I have tried removing the batteries and I still get the same results.  The camera is not sync'd.  What's going on here?
steve_t
Master Master
Swap the batteries for this camera with one that you know works. Also, try swap the position of it. See how you get on
