Arlo base station wired or wireless?
  • 1 Reply
  • 4646 Views
Crjeff
Will the Carlo base station hook up to a router via wireless or does it have to be via a cable?
steve_t
Master Master
Cable. But if you want it away from your router, you can use a range extender and plug the cable into that
steve_t
Master Master
