Hi my base is connected, first 2 lights are green but the third light is solid orange. I’ve tried reboot, reset, re sync cameras and nothing is working I can’t even get my cameras re added. Please help
Yes, I ended up having to remove all cameras and the base from the app. I then set it back up like i did when I first got it
Did you ever get your issue resolved? I'm having the exact problem, going on 2 days now.
Hey @Nighthawk11,
Are you still having problems with your Arlo Base Station going offline? If the third light is showing solid orange, it might be where your signal strength on your Arlo camera is weak or your internet connection is showing problems. Try to restart your Base Station to see if that helps. You can see more about the LED lights on your Base Station here: What do the LEDs on my Arlo or Arlo Pro base station mean?
I did what Jaybird did and I'm back in business.
