Arlo base station not allowing scheduling
  • 2 Replies
  • 2671 Views
abc41
My base station has erased my schedule, and now won't accept a new one.  Only the "schedule" option in "mode" highlights, but it won't accept a schedule.  None of the others (armed, disarmed, all motion off) will highlight.  What gives?  Can someone help please?  This used to be a great system, but not so much anymore....  😞
Sounds like your system is in an odd state. All Motion On or Off is a remnant of old software. I would reset the system by removing all devices in Settings, My Devices and then use the Add Device button in the Devices tab to add the base and cameras. That should regain sanity.
steve_t
Master Master
What firmware versions are your base and cameras running? Which Arlo app version and OS are you running?
