Arlo arm on/off
Reading the manual it states in Select a Mode when in Mode and click a camera, I assume this arms all the Arlo cameras. It only states Activate. I want to arm the four Arlo cameras and disarm with one entry.
If you click Armed, it should arm all cameras.
IMO the best thing for you do is create your own recording mode. You'll go through the steps of creating rules for the mode and each camera can be set at a different motion sensitivity and recording duration. You can even add extra rules that make one camera trigger another camera to record if you want.
You can select modes manually or have modes change according to a schedule or have modes changed based on your location (geofencing)
