Arlo Won't Connect To My Base Station
I turned the base station off at the power point, when I switched it back on all 3 lights are green on the base station but it still won’t connect.
That's likely an issue with the client you're using. App or browser? Have you tried both?
I am using the app., all 3 lights are solid green on the base station..
I get the following error:
Your device is not connected.
Make sure it’s connected to your router and has a working internet connection.
Have you tried a browser? Alos, log out of the app and back in.
