Arlo Wireless - I Cloud space
Can anyone advise as to how the system stores recordings in I Cloud? I currently have the 1Gb basic amount which I think will last seven days. Will the system automactically overrite the oldests recording or will I have to manually delete the recordings that I do not want. I have read that there seem to be problems deleting recordings as the system does not restate the space obtained following deletion. Is this still a problem?
Any assitance would be greatly appreciated.
The most important thing to remember is to D/L any videos you deem important when you see them just to be sure they don't go past the 7 day date.
I've had no problems with deleting files
Additionally, there is no space limitation anymore. Days only.
