Arlo Wire Free Second System at Marina
How do I set up a second system at a second location that has a key or a token? I can't get the app to see the base station but on the base station the internet light is lit? I went to the app and slid up to "add a device" picked base station and it just searches and finds nothing. Any ideas?
Jgreg65 wrote:How do I set up a second system at a second location that has a key or a token? I can't get the app to see the base station but on the base station the internet light is lit? I went to the app and slid up to "add a device" picked base station and it just searches and finds nothing. Any ideas?
To my knowledge, someone else had the same problem...a sign-in portal to access the internet. ( if this is what you mean ). The base might see the internet but your stuck at at log in portal to continue further.
Sorry to say the Arlo base does not allow for a sign-in, so you are prob out of luck
