I just put new batteries in one of my Arlo camara's. Still receiving the message 'change batteries'. When I push the synch buttom on yhe camara there is no light on front of the camara.. no blue light nothing. The other 3 camera's are working but only on few meters distances from the base station. What should I do?
Today I've received new batteries (Piscell from AliExpress). Both camera's are now working perfectly again.
Thanks for your help.
In general: The original batteries in the other 2 camara's still working after 5 months (66% and 68%).
The new batteries indicates 94% and 83%.
Gr Ben
Take the batteries out, and reinstall... verify they are in correctly
Also when syncing, make sure it's a QUICK press on the base sync button and then the camera
Txs.
The position of the batteries are correct. They are from one of the other camara's (original from Arlo) and 60%.
I've first push the sync bottum on the basestation for 2 seconds and after that the buttom on the camara.
Basestation reacts by blinking sync LED (3th). The camara LED didn't respnd at all. I'll first buy completely new set of batteries.
Yes... do not HOLD the base sync button for 2 secs... just a quick push
No results with only a quick push.
Now waiting for new batteries arriving within few days now.
Don't make it TOO quick, just long enough to get the Camera LED to flash and less than 2 seconds. I suppose I press for ~1/2 second but others have suggested 1 second.
Gr Ben
