Arlo When I go to settings, system is greyed out
  • 1 Reply
  • 4644 Views
Ron-91710
The user manual says to go to settings - system - preferances.  When I go to settings, system is greyed out.
Also, how would I write a rule to trun on the infrared ONLY at night and during motion?
Thanks to all,
Ron
Thanks to all,
Ron
Power button reboot your base unit....
IR settings are SETTINGS>MY DEVICES > pick camera > edit > VIDEO SETTINGS > toggle off/on
As a rule you don't need to do above... the IR illuminators when toggled on will only come on at Night ( when light levels are low ) and then only when a trigger event ( recording ) or manual live view..
PS, the cameras also turn to B/W when light levels fall
