I purchaced Arlo security lights to compliment my current cameras. Have updated the App to the most current version.
When I go to the app to add device, the security lights are not an option. What am I doing wrong?
Go into the app. Add device. Arlo Lights Bridge. It will get you to scan a QR code on the lights bridge. Then plug the bridge in and follow the instructions. Once the bridge is paired, you add the lights with another QR code inside the battery compartment of the lights. Did the lights not come with instructions?
Have you added the security light bridge?
I plugged the bridge in.
Did not see it in the app.
What is the install process?
Plug the bridge in and the app will recognize the bridge?
Yes they did! Thank you for your speedy help.
