Arlo Record Mode -When I Select Mode, Only The Base Station Shows
When I select mode, only the base station shows. I have four cameras linked but cannot access mode for cameras. Two cameras record with motion detection. How do I activate the other cameras to record? Thanks
If you see your base and click on the base, the cameras should appear as a sub set to the side
