In Device Settings there is a switch to turn on or off the camera.
To conserve the battery life I switch off the camera. Switching off works fine.
However, I can't switch the camera back on again. I've tried to sweep the switch several times with my finger. It just doesn't switch on again.
I have this problem for all my cameras.
Can anybody help?
I just solved the problem solved.
I just had to hold on to the switch a little longer with my finger before I swipe.
You don't save any power by turning off the camera in settings....it is a privacy mode esp when you share cameras...only the primary account holder can turn them back on.
( say in bedroom)
Disarming the. Camera uses the same amount of power...almost null.
