My Arlo has all the sudden stopped working and has a message saying it’s not connected to the internet! My internet is connected and on my hub the lights are lite up saying it’s connected but the app still says it’s not! Can anyone help me with this please?
Mine does the same thing. This whole Arlo thing is a piece of crap and I would never recommend it.
Hi @Cisn5766
What issue are you experiencing with your camera? you mentioned charging.. Is the camera syncing & appearing offline? Is it connecting to the base? Can you please provide a little more detail regarding the issue?
Hi @Cisn5766
6:30 pm 7/15/19 My wife just noticed a lot of blinking on cameras and base. I took one of the cameras that I had removed the batteries and put them back in. Then went to "Mode" and "Armed" the system. Result: - Camera's blue light came on then switched to rapid blinking for a couple of seconds then went dark. That camera is now working.
Repeated the process with 3 other cam's and they also came on line. Two others that are un-reachable at this time will be checked tomorrow morning.
BROVO - Looks like maybe someone took some steps ti fix the problem. We'll see if the "fix" lasts
Others - Please indicate if you see improvement
I spoke too soon - All but one went "off line", and will not come back at this time.
-What firmware is your base station running?
1.12.2.4_2772
-What firmware are your cameras running?
1.3.319
-Which Camera/Model are you experiencing the issue with?
H7 and H3
-Does the camera appear offline on the web browser & Arlo App?
Yes
-What Phone/Device/Model/OS Version are you using?
2.7.10 IOS
Same issue daily. I've had these for a couple of years and something has changed because this is worse than usual.
Yeah, same problem lately and also back in May, when they admitted they had an issue and fixed it.
I have given up on Arlo.
Hello,
If you are still experiencing issues with you camera(s) going offline, please contact customer support. I have attached the link here for you - Arlo Tech Support
Hi
I have the same problem. The camera worked fine for about a week. I had connected 2. Now everything is offline. It's very frustrating. I have changed the batteries, restarted the base/phone etc. These don't seem to be very good or reliable.
Any thoughts?
I found that there is a update on the camera. Once I did the update it worked great.
Both the camera and the base station are forced to perform the latest updates before the system can started.
Can you explain what you mean by "you found that there is a update on the camera"?
How did you do it? how do you find the update? What is the firmware version of the camera now?
Hi
I didn't find the update on the camera - that was someon else. I even contacted Arlo Tech - seemed to want to have my computer cleaned and didn't give information about why the system (camera/base) wasn't working correctly. I didn't buy into the computer problem b/c I know it had been working fine. I have disconnected everything and I am going to try once again.....if not back it goes.
Hi
How did you do the update on the camera?
