I have an original Arlo HD. I used to be able to turn it off if I was working around to save the battery. Now the Arlo app on my phone shows the perpetual spinning circle in the center of my screen only.
I turned off my phone and removed the batteries from the camera a few times. I also removed the device (Arlo) and put it back. Unfortunately, that didn’t work either.
Please advise,
Andrew6
Message 1 of 4
164
Hi Shayne,
No more. The message "This device is currently disabled and will not respond to mode change" pops up on the screen when I switch it off.
Works great, thank you.
Andrew6
Message 3 of 4
95
Hi @Andrew6
Are you still experiencing this symptom? Do you see the same symptom on the web portal?
Message 2 of 4
112
Hi Shayne,
Andrew6
Message 3 of 4
96
@Andrew6 Thanks for the update.
Message 4 of 4
85
