Arlo HD can has red tint
My Arlo HD cam has red screen. Tried opening the back. Tried disabling night vision, turning off, opening battery door for one minute. Nope
Normally that points to the nightvison IR filter being stuck.
You can try shaking the camera. Some folks have found that putting a strong magnet underneath the camera lens will move it. https://community.arlo.com/t5/Arlo/Potential-Solution-Red-tint-on-Arlo-camera-video/td-p/1694641
