Arlo HD Camera Battery Life
Hi
I have a 3 camera setup, and I am using rechargeable batteries however
2 cameras the batteries last about 1 month
but the third camera only lasts about 1 week, these are all about the same distance from the base unit
I have now relocated the camera, but this has made no difference
any suggestions
thanks
Are they all the same battery types?
Are they 3.7v li-ion?
Maybe they are just a bad set of batteries... try swapping them.
As a PS, i check my rechargeables and match them up by voltage before putting in usage ...if possible try it also they should read about 4.15-4.19v when off charge
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arelo Tech Support
Contacted support, they said they could not help, as they did not deal with Europe, so would get someone to call me 24-48 hours, (that was 3 days ago)
put fully charged batteries in last Saturday, lasted until Wednesday (5 days) other cameras with same batteries fine
Did you use the Contact Support link at the bottom here and chose a European contact number?
Hi
I contacted the support via the online chat system
